Well, here it is, at popular and unpopular demand, the complete instructions for setting up Doom-It-Yourself, for the complete C novice. I've spent some time compiling these to make them as easy to follow as possible.
The instructions are split into two sections: the online and offline sections. The online instructions are on this page, and you should follow them now, step-by-step, to obtain everything necessary off the internet. Then download the textfile containing the offline instructions, and you can get off the phone and start actually setting everything up.
All links are direct downloads which you should SHIFT-click on to download direct to disc. Where possible I have provided more than one link, in case one is too slow from where you are browsing.
Online Instructions
- Create a new directory on your hard disc called 'DIY' and open it. Put everything you download into this directory.
- You need SparkFS from David Pilling. If you do not have it, tell me and I'll try and set up some instructions to circumvent its use.
- Obtain the GCC C compiler
UK (Sunsite):
GCCmain |
cc1 |
Unixlib37b |
Clib |
Sockets |
Make |
Patch1 |
Linker
Germany (Stuttgart):
GCCmain |
cc1 |
Unixlib37b |
Clib |
Sockets | Make |
Patch1 |
Linker
- Obtain the original Linux DOOM source code
Direct from iD's site
Fast UK mirror
- Obtain the Patch utility
Stuttgart
Fast UK mirror
- Obtain the DIY archive
Author's website
- Obtain the latest update archive (currently M2)
Author's website
Offline Instructions
Download the offline instructions
Now log off and install DIY Doom! Best of luck!
